- 2011 Mustang GT
Spoke with my SM this morning after I'm having some turbo issues...PCV fix is postponed again, pending more R&D. This is at least another 90 days out.
Does this mean we can all stop paying our car payments until they get it fixed? Sorry, I'm feeling a little sarcastic this morning.
new turbo on the way from mazda for me. no word of the pcv system they initially mentioned. ?? anyway, i'll post my replacement stats here soon.![]()
Did you have your race pipe and cbe on when they examined your car and approved the replacement?
I just wanted to share my smoke experience w/ you all.I tried 5w-40 sythetic and run at 3000rpm for 15min and it still smoked.I heard 10w-40 conventional was it,still smoke.cobb catch can setup,still smoke.pt performance part,still smoke.and also tried turning the idle up,still smoke.I hope mazda's pcv valve update is the answer! Just called yesterday not avail. yet...
I thought you were only supposed to run at 3000 RPM for 1 min? Thats been what I have been doing and before I got the 5w40 synth swap it made the car smoke every time. 15 minutes seems like a long time to be sitting idle revving. I'm not a mechanic or anything but seems like something would make a car smoke regardless of internal issues.
As I posted in another thread, the free exhaust shouldn't be an issue. Mazda claims that the C revision of the turbo has an improved design of the seals that would counter oil leakage if the back pressure on the exhaust side of the turbo was removed/reduced.
Which company did you order from and what parts are you testing?
.. that didnt work out.. tuner steve.. that was for you idn why the quote thing got messed up.
Do some MS6's come with this fix?? if so how could i find out if mine does or doesnt?
im still running stock.. i have no smoke at all im just curious incase the STS comes about in my car.
there are some people who believe that the reduced back pressure resulting from the 3" system contributes to the smoking problem. They say that the back pressure in the 2.5" system helped offset the pressure in the turbo that causes oil to leak past the seals, reducing the amount of leakage...Hi Guys – just had my DP done to 3” car (MS3 2008 model) started smoking this weekend, badly.... Would you say that I should rather go back to 2.5” DP and get the Turbo sorted out with Mazda? I read the Thread and understand the PCV issue and changing the oil, just want to know if the 3” pipe is harder on the seals than a 2.5” pipe? My apologies if I sound ignorant and this might have been mentioned somewhere else?
