gear oil fill plug
tampa
Standard protege 1994
I have changed the clutch plate and now need to fill in new gear oil /transmission oil.
I can not find the fill plug, Filling through the speedo cable is difficult.
I have the axle out, can i fill the oil through the axle till the oil overflows?
can I use Automatic transmission fluid insted of 75W-90 in my standard protege 1994?
Please see my album for image on the transmission.
The fill plug is the same size as the drain plug. It's, if I remember correctly, toward the front of the car. You can fill from the axle, but the tranny takes a bit more than what you're able add from there.
Don't use ATF. Stick to 75w90.
