Can you sync your AP with any computer with AP manager? My main laptop with my APM on it won't connect to the internetz, so I can't update the firmware or anything, so I need to use another laptop. I loaded APM on the other one, but it won't recognize my AP. It plugs in and fires up, but doesn't show the vehicle info or maps.
does the APM recognize the AP. also what OS are you running on the laptop. if your using VISTA 64bit. you wont br able to connect the ap to the APM, because there are no drivers for the vista.
Well that answers that.
Can I download a driver somewhere or does it not exist?
Now I need to get APM loaded onto my netbook somehow.
Post that link for all to see, I'm running vista x64 and using VMware to run a 32 bit XP virtual machine with the APM on it. It works for now.
the link i had was for the other forum. and i think its not allowed to post other forums link.
Ok, I thought it was to a driver from Cobb's website. Sorry about that.
Is that the same frankenstein you are using to use your AP on Vista?
Basically. It works for now until Win7 comes out. I also use mine for the DH, since that also doesn't work on Vista x64.
Here's my setup for the LC/FFS:
Here's my setup for the <acronym title="Mazdaspeed 6">MS6</acronym>:
FFS Limiter: 4500
LC Limiter: 3800
Normal Limiter: 6700
SL Hysteresis: 4
VSL: 200
Going to check it out right now
I'm fairly certain you'll need to drop your VSL. Otherwise you won't be able to take the car over 3800 revs until you break the 200mph barrier. Good luck with breaking 200!
I lowered my rev limiter and I suggest you do the same while you're testing out FFS.
I dropped mine to 6000 instead of 6700. I still can't get it to work.
