Protege Garage Turbo Inlet Installed
Still haven't had time to install mine, however I did take some time with it using my grinder, a drill, some sanding rolls, a carbide burr, and a good washing.
I know Ken has been blasting these out to remove any dust or debris inside. That is very helpful but it's my opinion you should still double check before you put it on the car. I can tell you there was only a slight amount of dust inside mine upon initial inspection.
I looked inside with a flashlight and saw some dark areas in the middle, then I took a 2.5" dia scotchbrite type stripping / sanding wheel to the inside of it. You can get these at Menards or Home Depot or wherever. It barely fits the inside diameter but it compresses easily. I mounted it in a flex drill attachment which gives me the ability to use a smaller hand piece with a chuck on the end of it and access the inside the inlet all the way through. I connected this to my drill press and cranked up the speed.
I removed rust patches near the weld where the two halves of the pipe come together. This is not too surprising even though it's stainless tubing. I believe it's just part of the welding process and cannot be avoided. I also used a very long, tree shaped burr and some sanding rolls on a long mandrel to hit some of the rust patches and try to take down a slight mismatch between the two pieces of pipe where they come together. The stainless is very hard and difficult material to remove. This was probably totally unimportant in regards to flow but I tried anyway because it was there. Probably 40% was inaccessible with my tools so I quit.
If you ask me, the most important thing you can do is wash the inside of your inlet thoroughly before you put it on the car. Take a scrubbing sponge and soap with hot water and thoroughly clean the inside of the pipe along with the short BPV recirculating tube. Anything in the way of abrasive grit that could come loose and be taken into the engine is BAD. Washing it by hand is good insurance. Once it was dry, I wiped mine down inside with a light coating of WD40. I would do the same with any metal inlet or component going on the intake system of any car.
This is similar to what you would do when building an engine. You want everything meticulously clean and that's how I approached it.
Otherwise this looks like a quality piece and I can't wait to get it on the motor. Hopeful I can get it done tomorrow night.
This should not be necessary. I have never seen so many people wanting so much to like a substandard piece of merchandise that they will make any excuse for it.
I know of what I speak, because I am one of them.
Seriously, since when is it acceptable to pay for a part and have to do this much work on it before you can use it on your car? If I picked this up locally I would never have walked out of the store with it and neither would most of you.
anyone who is not satisfied with the product was and is free to return it. i realize these could have been and should have been cleaned thoroughly by the time half the shipment was out the door. it was not something done when we had them manufactured and should have been done there or through us. we've got 100 more of these coming in, are well on our way to selling through those as well and they will all be examined and cleaned as needed by us before they leave my hands. its as simple as that. its been brought up and recovered multiple times now. i wish i had seen that sooner and would have taken the time to go through that had i done so. if there is something else i am missing or something else i need to do here, something else i need to say or offer, feel free to tell me.
that said, when its installed properly and run on the car, it does the same thing as every other inlet out there for far less cash. if cleaning it out is a blunder i made on my end which relegates the product as a whole as substandard somehow - well, i can't say i agree with that.
if you don't like it or it doesn't do what we advertise it as, take it off and send it back no questions asked. my goal with this and everything else were working on is happy customers, nothing less.
I have always had excellent results (quick delivery, reasonable prices) when ordering items that PG did not have responsibility for the build quality of and will continue to purchase items through the company that it is reselling.
Any item that requires that much work is substandard. It should be ready to go in upon delivery. It wasn`t billed as a finish it yourself kit. The dirt isn`t even the major issue. This is a component that sits immediately before a turbocharger, an expensive piece of equipment, and it needed to be cleared of potentially engine threatening loose pieces.
You are absolutely right, I had the option of shoving it back in the box and returning it as soon as I saw it, but after waiting all that time, anticipating putting it in the car, human nature is not going to let that happen.
I have to agree with Mid's mentality, however, I will say that in the world of aftermarket, hardly everything just "bolts on". From body kits to bolt-ons, they'll all typically require some extra working to make sure it's perfect.
I just think the expectation was the same as the rest of the aftermarket parts out there - quality control already applied, parts investigated and checked thoroughly. Had it been mentioned it was an initial test run, people might have known more of what to expect.
That's all it boils down to in proper business ethics. Setting the right expectations go a LONG way for the customer as well as future interactions.
lawl.
So stop bitching? :)
I was afraid this sort of conclusion might have been drawn from my post.
Not only do I NOT consider this piece "substandard" as there is no such standard for an aftermarket TIP, I also don't let my expectations become unrealistic. It's a welded steel pipe assembly for $99 guys.
Case in point, some of you would send this part back if it had a scratch on it. Nothing short of perfection will satisfy your expectations for $99.00.
What I did was at my own option and was not required in any way and if I had bought for example a silicone TIP from another mfg I would have washed the inside of that before putting it on my car as well. Washing out the inside is the only strong suggestion I'm making regarding this part. All the other crap I did was completely my own ideas and optional.
So I guess I'll publicly apologize to Ken for saying anything about my fiddling around with sanding the inside of the TIP and potentially ******* up future business, all because of follow up comments by others with unrealistic expectations.
I've built engines, and I built an entire car loaded with over ten thousand dollars in aftermarket parts from various manufacturers. I've done all sorts of s*** to parts that likely weren't needed, and some things that were required to get things to fit right or work right. This is kids stuff.
Think objectively about any part you're buying and don't ever assume anything before you put it on your car. If you don't like it when it comes out of the box and you're not willing to do anything with it but bolt on and go, then send it back and continue your quest for the perfect, out of the box piece.
Amen brother. I come from the time when we had to MAKE OUR OWN own parts for hotrodding cars, there was no convenient aftermarket to shop from online. I haven't seen a "bolt on" part that I haven't had to fiddle with somehow. It's still WAY easier now.
The substandard is in reference to how much finish work was required. The piece fits and works. No complaints there. For this much money I was not expecting a beautiful piece with perfect, uniform welds, etc. I was expecting considering that we are car enthusiasts buying from a car enthusiast, a piece that was done, and SAFE to install, even if it was perhaps a little dirty. Having to remove potentially dangerous shavings that are clinging to the inside is not acceptable by any standards.
The first batch having these issues is one thing. Your supplier screws up, you jump on them and after that the workmanship is better.
Your (Wurf`s) piece is not in the first group. This should be done with by now. I brought it up (again) because it seems as if (in spite of Ken`s efforts) the workmanship has not improved from one batch to the next, and guys should consider that fact before buying something that requires work on their part to make it safe to put on their car.
For this price, do I expect perfection? Hell no. Do I expect function as delivered? Hell yes.
When this batch is sold out and the next batch is shipping, if I see more posts indicating the problem has not been solved, will I bring it to people`s attention again? You bet your ass. There`s a difference between tweaking something to make it exactly as you want it and having to do basic work to make it functional. The second is simply not acceptable.
there was only one batch of these, and nothing was said until well after half of that batch was sold, shipped and gone. there was no second batch until the batch we're presently having made now. wurf actually ordered his long ago (as he posted) and just now got around to installing it. so realistically there was nothing to be done at that point on my end.
If you read this entire thread, it looks like there have already been two manufacturing runs and a third is in process now. If this is incorrect and it is just a question of timing regarding delivery and posts being made, then I stand corrected.
If this new batch has no problems regarding drilling slivers, or loose welding slag, or whatever the dangerous crud is, then more power to you for taking the bull by the horns and getting your supplier`s act together. As I stated before, one bad run might be understood, but after that...
It appears then that my concerns are unfounded. This is one time when I`m glad to be wrong if that turns out to be the case.
Remember, I`ve said before that I will continue to be a customer for what you resell, as delivery is usually very good and the prices are reasonable. It just looked to me like your custom pieces needed to be watched carefully (at least this one). Maybe the trick there is to not be one of the first and wait for the kinks in the process to be ironed out. Of course, if everyone felt that way, nothing new would ever get sold...
bleeeeh! not even three days and im already being impatient for my TIP! lol
im just really anxious for it and I just want to see how it performs!!!!!!!!!
I like the look of the product, I'll be cautious it's nice and tidy before install. Thanks Ken! Paid.
How does the non turbine side of the inlet fit with aftermarket stainless intakes like aem, injen, cpe, etc. Im returning my CPE inlet because it doesn't fit very well with my injen intake. The metal "connector" piece between the two elongates my intake which messes up the CAI bracket that bolts it to the car. The bracket is no longer lined up with the bolt and ive spend 2 hours trying to mess with it to get it to fit. Instead of this extra metal adaptor flange they should have just made the silicon end a bit smaller so you can stick any intake in there and clamp it down. What a PITA. Hopefully if the PG inlet fits better ill be purchasing this one.
thx for any help
thx for any help
i have installed this inlet with a fujita intake, an injen intake, a CPe nano and full length as well as Cobb intakes. the Cobb is very snug fit but otherwise fine. the CAI brackets fit in the stock location as they do with the factory inlet.
