subsonicman
- 2002 Mazda Portege 5
my car idles real low, and puts a lean code out at idle, can i adjust the idle on my p5?
And wires. I had one go bad and it was causing occasional stumbles. I suppose it could be a coil pack too, but that would tend to affect two plugs at a time. Even so, easy to test, just swap them and see if the problem moves.check your plugs
Guys, this has nothing to do with bad plugs/wires.
There is an idle adjustment screw (IAS) on the side of the throttle body. This can be backed out to raise idle but only to a certain extent. There is a throttle adjustment screw as well but DO NOT adjust that one. If you have access to the factory service manual it explains it in there. I'm actually really surprised that you're getting misfire codes with just the CS cams. As for the lean code - that should not be there, head work or not. It does seem like somethin else is off though. The stock computer should be able to keep up with the CS cams and some headwork.
Also, have you considered the possibility you really are misfiring? What compression pistons did you go with? Hopefully you're running higher than 87 octane gas...
When you have cams that are more aggressive than stock and a decently worked head. The idle gets a little too lopey and the knock sensor doesn't like it. Feel free to read up on those who have installed "twiggy cams" and you'll see what I mean.Since when is a misfire not related to bad plugs/wires?
Since the OP question was about a lean code?Since when is a misfire not related to bad plugs/wires?
Try just regular old NGK plugs. Our cars are notorious for not liking anything other than standard NGKs. Seems like you might be onto a solution though. Good to know the CS cams and some headwork won't necessarily throw the car into fits. That gives me some hope down the road.Took out the NGK Ir plugs, and installed a new set of NGK Platinum plugs today, no change, I also changed my intake manifold gasket, and thortlebody gasket today, and replaced the EGR Valve, the Idle has at least become drive able, but it is still live able.
