Please sign on the dotted line. (stash)
X Neox
jeanspeed: if you are serious about the motor then let us know what you want from us...do you want just the motor and you'll find a place to install it? or would you like assistance in installing it?
we can do either, but if you need help in installing it then you will need to let us know so I can figure out some kind of transportation to get down there to help out
I don't want the guy to go checking which is the best motor until I'm ready to get it. They get mad "hi I'm an ass and going to get you to do work and then walk away and not buy anything from you, thank you" real mad... And if they do find which is the best they might sell it from under me before we're certain of a deal.
I recommended you to do the timing belt and water pump while the motor is out it's way easier 10 min job.(evil) While it's out. It's not necesary but it might save you money and time if it does start to give you issues down the road.
You really don't even need to do anything to it other than swap the fitings for the turbo.
dude im on call 24hrs so i dont know when they would call to to work. the address is 7737 meany ave bakersfield,ca 93308 shop name is HAVOC . Name of the guy is justine the owner of the shop. so if i dont or it looks like i wont be call i will let u know. my day off is friday. so wear should i find the T-stat timing belt and water pump. what hose should i replace. oh the number of the shop is 661-213(FAST).
You may need to get one of the hoses, i think one hose is different from the regular Protege. I'm not sure but you can take those in to an auto parts and have them match it up for you. I got a headache looking for the right fit for my car. It goes way different with the custom down pipe. The parts are all the same to a regular Protege other than that.
Is that what it is, I moved mine towards the driverside a few inches with no problem. I butchered the lower radiator hose cause it kept hiting the downpipe and swelling up. I just went to the muffler shop got a 10" piece of pipe and put it where it was hitting. No problem any more.
