Reading/Allowed
25/25 Test
HC ppm - 14/160
CO % - .01/.90
NOx ppm - 1355/1179
CO + CO % - 14.3/6.0 min
50/15 Test
11/166
.01/.93
1600/1304
14.4/6.0 min
High NOx with a good cat = bad 02 sensor.
Been there, done that.
Reading/Allowed
25/25 Test
HC ppm - 14/160
CO % - .01/.90
NOx ppm - 1355/1179
50/15 Test
11/166
.01/.93
1600/1304
14.4/6.0 min
On both threads I read, somebody asked about exhaust leaks before the cat. I definitely have one. What would an exhaust leak do to fail emissions?
Ok, so I went to Kevin's tonight and got a few things taken care of:
-Temp gauge is now working!
....aaaaaaand it's running hot. Surprise, surprise. New thermostat is the next step.
-O2 sensor is replaced. Old one looked like it was running rich.
-Adjusted the timing. I was running 17* BTDC, now backed off to 14. I'll still want premium at that setting, but it should help with emissions.
I'll see how it feels after I get this temp thing sorted out, and possibly bump it back to 16.
Also coming: New brakes. I need new fluid and pads, and I haven't looked at the rotors, but by the sound coming from the front driver's brake, I'm going to need those too. I'm replacing them regardless, since it's about $40 for the whole car at NAPA.
Thanks again, Kevin!
I think I'll try the Axxis Deluxe in front and Ultimates in back and see how that feels too. Cheap, and should do the trick.
LMAO nice. Quick and dirty, or take 5 minutes and do it right.
Actually, it only takes a couple minutes to take mine off because I don't have the bolts that go in towards the inside of the car, I've only got the 3 screws on the front, the 2 nuts on the bumper mount and the 2 bolts near the sway bar (the ones that go up, not in), all of which I can get to w/ my impact and an extension.
wait wah?? why the stronger pad in the rear unless you are trying to move the bias toward the rear more
bingo! In fact, a lot of folks run Hawk HP+s rear, and stock fronts. You'll see / hear them dragging the had brake going up to the line to warm the rear's upwait wah?? why the stronger pad in the rear unless you are trying to move the bias toward the rear more
You caught me. Those 2 bolts are giving me the edge I need!So you're admitting you are out of class?
This is going to be my next pad setup (maybe mid-season). The ultimates up front just aren't cutting it. Still too much front bias.I think I'll try the Axxis Deluxe in front and Ultimates in back and see how that feels too. Cheap, and should do the trick.
I"ve heard of CSP guys just removing the stock proportioning valve in the early N/As, making it a dumb, 50/50 system with pretty good success.if I was running something besides stock or STS2 I would change the proportioning valve or remove it.
