Rear lower tie bar and mid chassis brace.
i dont have this part, but my experience with Gt-spec from my protege tells me that it is most definitely a quality part. I dont think Ive ever heard someone with a complaint about their parts.
If i decided to use them with the stock setup, would i notice a difference?
EDIT: BTW, your car looks HOT and so do those rims. Are they custom painted?
yeah i would think that you would notice a difference. It will probably help prevent body lean in the turns and help you be more stable.
thanks, but no, the wheels come like that
I can only find them in silver. The black makes them look alot better.
tirerack.com has them in black. I got mine from swampass, but i know captainGJ has them in black as well and a few other people have been looking at them too
the mid chassis brace offered by gt spec. It is to replace the mid chassis brace already on the MS3. Look under a MS3 and see the big plate underneth. That is what the gt-spec mid brace is to replace. So basically it might be a little better than the stock plate. But for the money i would go other mods first.
the mid chassi brace mi woudl say holsd on. if you look under s ms3 that big plate int eh middle. Thats what the mid brace replaces. Might be a littel better than the sheet metal. But spend other places first.1
What the heck did you just say???(flash)
Thanks!
I reread what i type. Sometimes i mis the mistakes. But i try to make it clear. oh argh
thanks!
I don't see what mods you have already in place, but if you want to improve handling, stiffer ARBs will give you great bang for the buck. Check out the Hotchkis ARBs on the same catalog page. The chassis braces will be very hard to tell the difference.
If you want to stiffen up your cornering, then get the new rear/front sway bars that are out for our cars. Cobb and one other manufacturer has them out now. Stiffer and lightweight. I would do the braces last, as the bang/buck factor is MUCH lower for the braces.
