airbox mod
1 more in the airbox and 1 at the bottom of the resonator
you will haveta go under the car for the resonator
Then 4 under the long plastic, 1 under the resonator what which one on the airbox?? have any pic?
Nope as the moment no
its dark outside and i just put everything together had to tape up my airbox cuz im missing one of the clips. the clip should come in sometime this week then i can take off the tape and take a pic
damn man, Im just itching to do this mod. My car is going to the shop tomolo, so I will prolly get it done in the next few days.
this is a great forum, haha
Why to the shop? mod didn't work? you ****** it up? (jerkit)
lol
btw i'll do my mod tomorrow and post pics
Alright, I did the mod this morning. It wasnt as easy as I thought, took about an hour, with a lot of cutting and trimming and grinding. It came out great, though I didnt notice any performance increase like others have said. i THINK it pulls harder when accelerating, but it could be just the placebo effect.
Its ok, its free, didnt expect much.
Did you reset your ecu?
and if goldstar can maybe answer this for me...if i remove my grill to be replaced with mesh will the ram air effects be gone? Instead of air getting shoved through the opening we have created, it will just hit the grill and rush into the engine bay with little air being forced into the snorkel. Any thoughts on this?
I'm gonna put a weapon ram air directly to the airbox... place it on the right small grill or maybe the one on the front
Yes and pump the brakes a few times while you wait like 10 mins.
It will help the Ecu relearn faster with the new amount of air it is getting.
while the cars negative battery terminal is disconnected and just leave it disconnected for like 10 mins
hook it back up and drive wild for like a 100 miles and your ecu will compensate from the new gain in air.
Yah when i did the cutout mod i felt a good improvement in lower end tq
took me less force to push the gas pedal in to get up to speed quickly.
When i install my exhaust ill probably reset the ecu again and feel more gain on the butt dyno
ok so after you do the mod.. you disconect the negative wire from the battery.. pump the brake for like 10 mins.. then re-connect the wire and then???
No just pump it like 10 times and then wait for 10 mins.
Hook the negative back up start the car and take it out for a afternoon spin.
Try running it harder then you would normally do and then the car will settle down to normal with more hp gain.
So instead of pumping it leave it there for 10 min.. ok
btw when i leave it there..the jeys shoudl be off or on stage 1??? like hwne all the lights turns on on the dashboard
well after takin my time to read this
umm all you do is
1. unplug negative battery terminal
2. go in car and pump brakes a few times
3. leave your car sitting there with keys out completely untouched for about 10-15 mins the time doesnt really matter.(i usually just grab some food or skate for a while)
4. reconnect battery
5. take it for a drive i usually reset my ecu before trips so the ecu will have relearned itself when i get back to wherever
6. enjoy some newfound hp and tq cuz the rest of your mods are not this free.
i didnt pump the brakes after my CAI and headers...does that mean they have not done anything for me?
nahh, pumping the brakes just helps to push the last little bit of electricity out of the system. as long as it stayed unpluged for a bit, you should be fine!
