Then 4 under the long plastic, 1 under the resonator what which one on the airbox?? have any pic?
damn man, Im just itching to do this mod. My car is going to the shop tomolo, so I will prolly get it done in the next few days.
this is a great forum, haha
Alright, I did the mod this morning. It wasnt as easy as I thought, took about an hour, with a lot of cutting and trimming and grinding. It came out great, though I didnt notice any performance increase like others have said. i THINK it pulls harder when accelerating, but it could be just the placebo effect.
Its ok, its free, didnt expect much.
Did you reset your ecu?
and if goldstar can maybe answer this for me...if i remove my grill to be replaced with mesh will the ram air effects be gone? Instead of air getting shoved through the opening we have created, it will just hit the grill and rush into the engine bay with little air being forced into the snorkel. Any thoughts on this?
while the cars negative battery terminal is disconnected and just leave it disconnected for like 10 mins
hook it back up and drive wild for like a 100 miles and your ecu will compensate from the new gain in air.
Yah when i did the cutout mod i felt a good improvement in lower end tq
took me less force to push the gas pedal in to get up to speed quickly.
When i install my exhaust ill probably reset the ecu again and feel more gain on the butt dyno
ok so after you do the mod.. you disconect the negative wire from the battery.. pump the brake for like 10 mins.. then re-connect the wire and then???
No just pump it like 10 times and then wait for 10 mins.
Hook the negative back up start the car and take it out for a afternoon spin.
Try running it harder then you would normally do and then the car will settle down to normal with more hp gain.
btw when i leave it there..the jeys shoudl be off or on stage 1??? like hwne all the lights turns on on the dashboard
