WRX 440cc Injectors
after i get my fogs, next on my list is the afc, 440's and wideband. i hope by the time i get them there are soem maps. if not i might just have to run my ass out to tampa....lol
Yes i've been running 14psi on stock rods for about 2 months now on a dynotuned DSM's AFC.
well i installed the injectors the nite b4 i got it dynotuned it for 14psi so i can't tell you if it runs any better or worse. i can however tell you if you drop the 440cc in while on the supermap your car will jus bog the entire time in boost so it will absolutely need to be retuned.
on a sidenote:
although i did get it dynotuned, they did not provide me a dynochart w/ the AFR, jus hp & tq, so i have nothing to send to dsmconvert. also i don't have a laptop or the serial cable needed to extract the maps from my afc to share w/ others. however, if someone in the Philadelphia or Harrisburg area has the equipment and know-how, i would be more than happy to let him copy the files to share w/ everyone.
im running the unichip with stock injectors.
spiking at 14psi then settling at 12psi all the way to redline.
so far so good, although I know the injectors have to be near maxed. Been running this for over 8 monthes on stock block. But not for long, MAM longblock was ordered last month!
Werd I need a map bad! Im gonna try and tune my car this weekend and post up some maps! Does anyone have at least a super map that they can send me? I only have a map for 7psi to work with :(
yea I've been waiting for someone to get me a dyno run so I can fine tune a map...We did a rough tune for someone on here running 440s....basically we just cut all the map values in half and then tuned from there... 101 yours has the supermap on it...or atleast it was originally loaded with it when it left the shop...speaking of which did you try to call me the other day...I could only understand about 3 words of the message if it was you...
yea that probably was me! im trying to get this thing tuned before track day on the 13th and wanted to know if you could help me tune it cause I also have a ported intake manifold and throttle body to go along with it.
WRX 440's, stock spacers and such
20psi, Megasquirt controlled.
4 injectors, no extras.
new motor has 1k miles on it.
stock fuel rail and FPR, Walbro in-tank pump.
work marvelously, with that cool Walbro whine.
-Mateo
i'll get you something within the next two weeks. I jus got a LC-1 wb and plan on going to a dyno day on oct 15.
Paul said:
can u put the injectors in w/o any tuning?
I just sent you a reply back to your PM
you need something to control the bigger injectors, emanage, haltech, aem , microtech etc etc
and yes you will def need to tune them
101, hehe damnit leave me a message, ive been working with porsche during the day so the only way i can get back to you is if you leave me a message so I can call you back...I can prob help you tune the injectors here next week...did you ever get a wideband installed?
Not yet! I'll leave a message today because I need to talk to you about a few things!
