Mazda locked out autorun from an external source and require a signed cert., per the AIO developers:
background:
The new version of 59.502 firmware was secured. this is good for normal Mazda owners.
We don't want to someone put a usb with music to our car and silently install some troian in our cmu with access to canbus, and software upgrade capabilities to other systems.
the problem [For AIO users]:
a) the *.up files run BUT not execute external files that we use to run scripts from usb
SO usb storage now not have "autorun" option
we can't create *.up files because we not have the private keys of signer certificate
b) SSHd was secured from an earlier version too (root password change, and disable password authorization on sshd)
So security is enhanced greatly in .502, which makes running these mod. apps much harder. They do describe a workaround but it's pretty complex and requires some Linux knowledge.
I wonder if it's possible to downgrade the infotainment software?
Can you post a link to where the workaround is described?
I'm very comfortable with Linux and want to give it a try.
Thanks
agc
Works with touch and the rotary dial!
Settings. Go to the last tab on the right. It's under "About".And here comes the noob in full force... How do I do that?
Does the navigation (google map) works on the Active Display, just like the default one?
That's why I am asking questions... I'm locked out by Mazda anyway...For noobs in full force I recommend reading up on it and UNDERSTANDING the risks you take.
You can go to mazda3revolution.com and read up on the AIO thread that is running at +4600 posts! (Disclaimer: There will always be a potential to brick your system so.... proceed at your own risk!)
Keep in mind that it is really dependent on your system version. I still had the original one (59.00.441) so it's compatible. If you have a version higher than this then it's a royal PITA that I think requires some fiddling with hardware.
Thank you sir@Soarhawk Do you mean does Touch work? Settings. Go to the last tab on the right. It's under "About".
Just attempt it. That's a built in safety that if it isn't compatible It'll stop itselfIs it possible to do these on the newest version yet?
