You can come to a point where you spread the weight of the vehicle too greatly across the contact surface, actually inhibiting grip. I know this from my experience with Pro Street V8 setups. Having a fully tubbed out truck with tires that are 20" wide may look cool, but anyone with experience trying to make a race car/truck grip will laugh at that knowing how much additional weight, drag, and reduced grip that person has just paid for.
My advice is to stick with the manufacturer's initial wheel size and try to improve on the following:
Find a tire (OEM size or maybe 225/45ZR18 max) that fits your needs better
Find a wheel (OEM size) that you like the looks of better, but is lighter
If you're going to the strip:
- Find a set of 15" or 16" wheels that weigh as little as possible (reduce unsprung weight)
- Pick up a set of street slicks for those wheels
- Use semi-truck scales and manipulate your coil-over suspension to achieve as close to a 50/50 weight distribution as possible
