well i did new struts and springs a few months ago and also put on ford enlinks. none of them are snapped but i have yet to try to re tighten (since i doubted that they would loosen up after months of not having problems).
i always torque, then re torque lugnuts to 68ft/lb.
Did you change the strut mounts as well? If they're still the original ones that could be it. You *might* be able to recreate the sound by finding a fat guy to bounce the front end of your car.
clunk is kind of random and difficult to recreate with. as long as the car is moving and there is small about of bump or even going over the little bumpy things in between lanes might or might not make it clunk.
it does feel to be on the drivers side and will occasionally sound on the passenger side.
the wheel can be straight or in motion when it occurs.
If it does it over small bumps that might be a good thing, something would have to be fairly loose in that case. My left control arm ball joint used to make a
clack sound sometimes when entering my driveway (I have to drive over a ~5cm bump). I couldn't diagnose the sound using the
normal method because the ball joint wasn't loose enough. However, I recently changed my control arms and sure enough the left hand side ball joint was much looser than the right.
If I were you I'd start by doing the test I linked to to check for any slop in your tie rods and LCA ball joint. If that reveals nothing, then try removing the front endlinks and see if the sound goes away. If that doesn't help, I'd pop the LCA ball joints from the steering knuckles and check for excessive play (the ball joint stud should be relatively hard to move). If all of that checks out ... then I don't know what to tell you.
Front end clunks could be caused by the following (off the top of my head):
- Bad struts
- Strut mounts
- Stablizier end links
- Inner/Outer tie rod ends
- LCA ball joints
- Loose mounting fasteners
It shouldn't be too much work to rule most of those out...
can someone do me the favor and check if when your in the car (with it running) at a stand still turn the wheel left and right rather quickly as if you were going through cones, is there any kind of clunk or tap in the steering wheel?
i dont remember if my car has always done that or not. (my car wont clunk at the wheel if its in the air)
That's normal, I have brand new inner and outer tie rod ends and it still does it. I think that noise comes from some slop in the steering rack, but you really shouldn't worry about it. This isn't the noise you're hearing while moving.
One last thought: have you played around with your motor mounts recently? A loose mount could cause a clunk but you should be able to correlate it with hard acceleration/deceleration. Perhaps you should check those bolts as well as any other bolts related to your suspension to make sure everything's good and tight.
