Careful Mike, you could get yourself banned posting that stuff. No I'm not going to Narc on you, just saying.
Yeah well ill delete it lol
I'm actually boosting above that but yeah, when I loaded the map from the afc to see what it was on it was all 10s. I guess ill check it again and try that.
you sire have vac leak issues which also equate to boost leak... when i had a vac line not connected to anything wide open. I was still pulling in 16-17lbs of vacMy idle vac is 75% of that on a warm day and 50% of that right now.
So my ssafc lost its map, I reloaded it and I'm not sure its working. Getting super lean at wot now which is very odd. Could it be fuel pressure issues? Is there an easy way to turn off the afc without removing it?
I figured thats what happened with the map. sometimes it will even change all the numbers. put it to 10 like said above.
if your interested, i can show you how mine is wired. its basically plug n play so i can put it to stock incase i have issues to resolve (adding a piggy to the mix creates a huge variable in troubleshooting)
Why do I stumble across good deals when I shouldn't be spending money!? Tein S-Techs locally for $160...
You know what, I just might want to verify that they're new... LOL I know they never went on his car...New? Used that is not that great of a deal. I have seen them used on the forums sell for less.
