is your whole valve cover as sexy? seem to remember it was textured somewhat. looks damn good though. damn good. might do that to my heat shield
No, thats the only part I did cuz it is textured and it takes time. maybe one day
yea that mothers mag and wheel polish is the s***, just but the powerball attachment for a drill...wet sand it with some 1000 then 2000 grit, and hit it with the power ball, it'll come out like a ******* mirror.
I repolished my brothers injen intake pipes, man...huge difference
and to figuejos, i would take a rag and hand polish a little more around the letters on the heat shield and in the tight areas on the lines. Looks good so far though
thought it was h7 since the msp has high an low in the same bulb, unless I'm confusing protege and p5 light bulbs
ya I think the H4 is the fog light, but either way im not sure right now, and you can just look this stuff up on autozone.com.. pretty easy
Fogs are H3, headlights are H4 (dual filament)
So jealous of the grip that measurement will get you...
What size 15"s you running? I need to get an autox setup.
Going to be keeping the MSP a while. Been driving it the last few days, and its not broken down *knock on wood*, and actually been a little fun.
H7 are P5 low beam, i think P5 high beam is 9006, H4 are sedan headlights, H3C are fog lights (i believe, I know regular H3 HID's wont fit in the fog lights)
Running 225/45/15's. Did my first event of the season last Sunday, and can now confirm, R-comps are the most amazing thing, ever. I still can't put the power down, it just smokes the tires(even on stock boost levels, 6.5 psi), but the corner speed and lateral grip have increased by a pretty large margin.
Now I need to train my brain to look further ahead at these new speeds.
R-Comps are great. My last dedicated autox car was an 03 V6 tiburon on 16" A6's. 235/40's all around and -2.1 camber front -1.9 rear
I also meant what size wheel as in width / offset?
So.... anyone got a spare bolt laying around for the ABS wheel sensor to bolt it to the hub?
My ABS light popped on last night, and found this morning the bolt had come loose on my right front wheel speed sensor.
lolz
If aint one thing its another
What kind of crank pulley is that? Looks crazy
