protegerider
- Mazdaspeed Protege
installed the medeival front and rear motormounts yesterday. the rear mount took about 2.5 hours, and it was not as bad as everyone has said. Also there is not much vibration at all.
Tried to install my walboro fuel pump that I ordered from PG but after getting to the pump and trying to install the walboro i found that the walboro is longer than the stocker and thereful could not successfully close/clip the housing on top to hold the pump in place. So back goes the old fuel pump till I figure out what the deal is. WTF.
I rotated my tires, changed the oil and lubed up the rear sway bar bushings this weekend too...and gave her the weekly bath.
does it change exhaust tone?
catless or high flow cat? Tight fit as in the 02 sensors bung placement?
Nah the 02 wasent a problem. time consuming extending the wires but not bad. the flange to the dp was a freaking ***** to get on, the flex pipe helped still used a mallot tho... I went with a high flow
I ask because I have a midpipe at my house that I need to install but I need to extend the 02 sensor wires as well. I just thought some dumbass put it on the wrong end of the pipe.
Edit: Would you suggest just buyign one of those pnp 02 sensor wire extentions?
Well... I tried to get the motor out again saturday, it was a no go... I am still stuck on the wheel hub... I cant get that nut off of there, but for some reason one of my friends decided to try and get it off while I was helping someone else with there car, and yeah I definatly came back to the garage to see he decided to take a dye grinder to it to try and free it up a bit, so now I might as well just cut it off since I have to buy a new axel now due to him cutting part of the shaft... needless to say I was not happy...
Pics of what he did? You may be able to fix it but who knows. What's wrong with the nut on the hub why won't it come out. And why is an axel holding you up from taking the engine out?
that dude wouldn't be walking anymore if that were my car. My solution was a 2 by 4 set on the breaker bar.... then just a lil hop onto the 2 by 4, end or problem.
Unbolt the hub from the car and just pull the whole hub from the car with the axle that way you can get the engine and everything out if that nut won't come off...and just put it back in the same way...saves you from having to buy an axle as well.
