any tranny fluid you guys would recomend?
shockproof is fine if you want to change it every 3K miles. if not... bad plan.
the advantage of shockproof is calcium carbonate crystals that get crushed as the transmission is lubricated. This absorbs stress that would otherwise be transmitted to the teeth of the gears.Well atleast in my case, thats absolutely not true..Ive been using that thing for the past 3 consecutive years with absolutely 0 Problems and way more than 3000 miles on the oil, my tranny shifts smooth, no weird noises, gears, synchros and lsd are working flawlessly even when i flushed it to get the engine out with axles the oil still looked almost the same color it was when i fill the tranny 3 or more years back. like i said above atleast thats not a true statement in my case.. Its better than the MT-90 for sure once again to me and my specific application..
Once all of it has been crushed... the fluid is spent. Its NOT meant for DD use.
lucas is good too. I'd say on par with redline and royal purple, just less common. MT90 would do you well.well mine is most def driven as a dd. and alot of miles so would the redline mt90 be good? i was recomended by a friend of mine to use lucas but i wanted to see what worked for everyone else
Someone told me GM synchromesh is really good too.
Me or Korey
