Bought a laser line do use with my FM alignment kit. I'm going to state the obvious: lasers are WAY better than strings. By all of it.
I measured and marked a centerpoint on each subframe to establish a center line. I used the laser aligned to these two marks to cast the center line down onto the tape measures attached to the alignment hubs. This let me easily set thrust angles on each wheel and made it really obvious when I accidentally shifted the car when tightening a bolt (which happened way more than I thought it would). Huge improvement in how easy it was to do an alignment.
Final alignment specs-
Front
4.8deg caster
-2.2 to -2.3deg camber
1/16in toe out each side
Rear
-1.55 to -1.6deg camber
1/16in toe in each side
Was raining last night so I didn't take it for a test drive, but I will update once I am able to do so.
View from under the car while aligning the rear axle.
The alignment hub, camber gauge, and tape measures all attached to the front passenger hub.
The laser cast across the tape measures on the front axle.
Question: I see some people suggesting more negative camber on the rear axle, and many others suggesting less negative camber on the rear than the front. My thoughts in using less negative camber on the rear is that I don't want to sacrifice too much linear traction for lateral traction given the extra power my turbocharged engine has. Does anyone have any guidance or wisdom as to rear camber settings?
Front
4.8deg caster
Rear
