? You don't?Did you see the DEF on the checklist?
HahaHey your power steering fluid levels are A-OK
Right, but mine is the Type R, so any video I made would apply only to my Racecar.
? You don't?
Haha
Nor the gas so you're covered either way
One of the few cars I've owned that I can easily see going big mileage in (150+) A/C and lifetime tranny fluid are primary concerns that could prevent.
? You don't?
I plan on doing regular drain and fill for transmission fluid. That looks very straightforward. I've had good luck with A/C in the past, hope it continues. Is Mazda more prone to fail, or more expensive to repair?
I'm more concerned about the various electronic technology.
Nothing hereDid you see the DEF on the checklist?
Here.Nothing here
So, one thing I've been wondering is what happens when you drive into a Jiffy Lube with a Diesel CX-5? Will that go well or is an oil change now a do-it-at-home thing / go to the dealer thing?
Here.
2.2D requires low ash oil, so unless you can ensure Jiffy Lube is using the right stuff...
Heck, even doing this at home is getting harder and harder!
I live in an apartment, so doing it at home is out unless it's ridiculously simple.
Having to get to the Mazda dealer for an oil change is very much a non-trivial problem.
Over here, service interval which should include oil change is every 10000km (6213 miles) or 12 months which ever comes first.
Thing is, there's only one Mazda dealer in these parts and it's not in the city where I work. I would have to take a 1/2 or full day off to get the car serviced. And dealers aren't known for their low service rates.
LOL! This sounds like my problem also.... Are you also in Norcal?
