Under Hood Turbo Smoke
sirmudge
Blazing Yellow Mica 2003.5 MSP #1291
When I boost with my car lately it will perform just fine, but i can smell something burning. When i stop and open the hood i find that there is smoke coming off of the turbo. Anyone have any thoughts?
Check for oil or coolant leaks on the turbo oil and coolant lines. If it's leaking from the seals inside the turbo you need a new turbo. Coolant and oil smell very different when they burn, you are likely smelling/seeing oil.
I found a leak between the turbo and oil return pipe, so i am going to change the o ring in there and see if that fixes it.
i just did that oring 2 days ago it has to be ordered at Mazda n costs less than $2.00 it took me about 1 hr to replace cuz its a Pita to put it back on without removing the oil drain piece from the MBSP. but my leak is gone so give it a shot
I just found it on Callaways website. http://shop.callawaycars.com/O-Ring-Turbo-Oil-Drain-Fitting-MSP10015002.htm I think ill order it from there instead.
LMFAO yea 89 cents from them right? but then theres the shipping
Select a shipping method for items sent packaged.
* Marked fields are required.
Select a shipping method:*
UPS
UPS Ground
$10.15
UPS 3 Day Select
$15.24
UPS 2nd Day Air
$20.13
UPS Next Day Air Saver
$48.18
UPS Next Day Air
$52.42
UPS Next Day Air Early A.M.
$85.42
UPS 2nd Day Air A.M.
Not available for this shipment.
U.S. Postal Service
$15.00 Flat Rate Shipping!
$15.00
Free with $50.00 purchase after other discounts
yea ill stick to paying 1.80 at mazda and free shipping
Yeah i paid a bit extra for the part, but i am OK with that because my car is working just fine again.
