Turkey help!!!
Ch1ck3n
2003 Mazdaspeed Protege
I just installed a cold air intake and front mount intercooler from cork sport and a bov from forge..... my Turkey has never sounded louder but I want him dead
Does anyone have this same set up that has information on how to kill the turkey???
ive said it a million times - the dual setup is retarded. when something is wrong it means its twice as likely to be BOV/BPV related and even harder to identify correctly.
relocate your MAF to your cold pipe now that youre on hard pipes. two reducing couplers and a hacksaw is all you need.
QFT.
Why buy 2 devices and increase your chance for a leak.
When the original Turkey thread was started The MSP was still new, and in all reality running the Dual set-up was the smartest option. No one knew whether or not the MAF could handle living on a boosted pipe. Many years later we've learned that the MAF can in fact handle the boost so now the relocated MAF is teh better option.
Although there is one member that keeps posting a pic of his exploded MAF after he relocated it....5-10 PSI isn't going to explode an MAF... I'm willing to bet it was more a combination of over tightening causing a crack or stress fracture, bouncing/vibrations, heat, and some pressure from the pipe.
For me to relocate the MAF, I would have to buy a new cold pipe cuz of where my BOV is located. I wouldn't have room for the MAF between TB and BOV
Post a pic....
if the pipes are all the same size without any major bends you could just cut the whole pipe and flip it then cut a chunk from the end closest to the intake mani to fit the MAF.
I personally have the BOV on the hot pipe for I have no worries.
