Little Beavis posted this:
Some specs for those who care:
Knock retard can be set to max out at 10 or 20 degrees. If the unit detects knock it will pull timing. At the 10 degree setting it will pull timing in 1 degree increments. At the 20 degree setting, it will pull in 2 degree increments.
You can choose to retard all cylinders equally, or individually. Thus if you have knock on cylinder #4 and only on #4, you can retard the timing on that cylinder, while leaving the other 3 at full power (timing). Very cool.
You can set retard based upon boost. You get a dial that allows you to set a value ANYWHERE between 0 and 10 psi. This is when the unit will begin to pull timing. How much timing you ask?
Well, with another dial, you can set how much timing it pulls per psi of boost. In this case, a similar dial allows you to select between 0 and 2 degrees of retard. So, if you want 1/2 degree per psi, turn it a quarter of the way. Want more, turn it more. What 7/10th degree per psi, turn it 35%. You get the idea.
Then a "new" function. So you can turn down timing at boost, so you can retard timing when it senses knock. What about preventing knock at your torque peak? Well, it has a mid-range rpm based retard. You have a programmed (sorry, you can't change it, but you can have it programmed wherever you like) mid-range retard. This is designed to pull timing when the engine is under load (and making boost) and at a predetermined rpm range. In my case, I have it set to ramp up evenly from 3000 to 4000 rpm where it max's out until 4500 when it ramps back down to 5500. This means that I have full timing advance below 3000 and above 5500 when I'm boosting (except for the boost retard and knock retard) and I have full timing any time I'm not making boost. In fact, it also ramps up and down with the amount of boost I'm making, so running "loaded" at 1 psi, does not affect the timing. THUS MORE POWER!
Anyway, I'm sure those of you that took the time to read this novella, can see that I'm excited about this. I know that there are other things out there, and a nice piggy back or standalone could do something similar, but you have to feel good about having three ways to control your timing on a car that we have up until recently had NO control of timing whatsoever!
Anyway, that's my story, time for bed. . .
