Turbo install this weekend
snowblazin said:
Lol, thanks Mark! I'm really torn about starting this tomorrow. I dunno if I should start and order needed parts I can't find as I go, or if I should order the rest of the s***, then begin.
i personally would get all the parts but thats just me.
shaneMazda2000P said:
agreed, i had to drive a 97 explorer for 3 days...
LOL, I have a 98 GTP w/ over 200k miles. It is supercharged though! (glare)
lucky.... lol
edit: what type of bov are you using... i just loaded a clip of mine... on 2psi... check sig
I would wait till you have all the parts. It will be a lot easier to do everything at once.
And Shane it doesn't sound like the BOV is releasing. It just sounds like the actuator releasing into the Intake. The turbo xs should be a solid release. If its surge it could damage the turbo. Not 100% sure since I only have a sound clip.
lucky.... lol
Using the stock BPV. Complete stock setup.
my 96...just got rear ended an hour ago by a kid doing about 40+ didn't see me till the moment before impact...his car is gone! i lost my bumper, drivers rear fender and lift gate door...about 2k...
have all the parts man! or at least all the parts you think you need...
That sucks Mark! I was gonna say something about a threadjack, but I can't complain if you keep posting pics of your daughters. :p
hahaha....i figured as much!! let us know when you're ready to go....so what is left to get now?
Banjo fitting for water feed, random nuts and a check valve. I think that's about it...
so what are the sizes for the water inlet and outlets?
the banjo fittings for the water lines should be 14mm, I just installed mine last night that I got from ATP turbo, its 14mm - 1/4npt
