Trunk Question/Info
DarthNewky
260th MP3, Blue Mica
Alright, was cleaning out my car and wiping down some of the trunk and just overall inspecting it.
Found three things, two are just info to let you know how to turn your trunk light off if u didn't already know
The third is a chunk of rubber, that i have no idea what it does
Way number One to turn the lights off is to take your key, and press the Trunk latch so it acts as the the trunk is closed, easy enough. However, before closing, please make sure the press the little Yellow/Green thing on the right side, down to the bottom and in until you hear a clicking noise(Light should come on). Then you can opperate your trunk as normal.
Way number two is described in the Image below
Basically it is just disconnecting the lead to the Switch in the Trunk Latch assembly
Object number three is pointed out also, and i have no clue what it does....Does anyone know
:wtf: is it
Bad Image
