Is this a known problem?
Today I went to swap my stock rims/tires with my winter steelies/tires but had no luck...the stock rims are seized to the hub/brake mounting surface...I had to use a huge amount of force and was finally able to remove the front driver side, but then went on to the rear and had NO luck at all...it would not budge! I tried using some lubricant to see if that would help but still nothing!
has anyone else had this occur? what are my options here? I'm thinking about going to Mazda to have them fix this problem, is it covered under warranty? this is a very big issue....say I were to get a flat out of the city, and had no means of contacting a tow-truck, I would be unable to change to my doughnut!?!
any help would be great...TIA
