Little Beavis
- 2001 MP3-T (#911)
Holy thread. . .as stated several times (but I thought I would chime in since the picture posted is of my transmission). You need a speedo sensor (the plug with the white gear that goes into the transmission). There was one of these on your LX tranny. There is not one on the MSP tranny, but one can be put in by removing the "plug" that is in the speedo sensor spot.
As for machining the diff to accept the pink speedo gear. That is an option, but difficult unless you have a machine shop in your garage. Instead (as already pointed out), use a dremel to remove just enough material to press the pink gear on to the MSP differential. Then with that pink gear, the sensor with the white gear, and your stock wiring harness. . .you're ready to go.
