Young Roids
- The pennies have been saved the MS3 is mine!
HOw does tire rotation work with the tpms sensors? Are the front wheels set to a higher setting than the rears? And will rotating the tires throw it off?
STOP!
If you rotate the front TPMS sensors to the rear it will certainly tear a hole in the universe.
is that 27psi cutoff an adjustable setting? could you have the dealer bump it up to 30 if you wanted?
