tpms and tire rotation?
Young Roids
The pennies have been saved the MS3 is mine!
HOw does tire rotation work with the tpms sensors? Are the front wheels set to a higher setting than the rears? And will rotating the tires throw it off?
STOP!
If you rotate the front TPMS sensors to the rear it will certainly tear a hole in the universe.
once again mazda forums just brimming with usefull info. You might as well throw in some vtec jokes as well for good measure.
It's fine. The sensors set the light off at 27psi no matter what. Doesn't matter whether they're front or rear.
Ok so all sensors will go off at 27. See I was thinking that they would go off at a 1 or 2psi drop so that the difference from front to rear of 32 and 34 would set them off. Well this means I should be checking my pressures more often. I thought I could just rely on the tpms light to tell me when I was low.
