tritonheat1,
Wow, we're brainless boneheads, OK... This is why I never post on these forums.
Anyway, you are right gear ratios are very important in the top speed. I didn't see anyone on the forums disagree with that.
Gear ratios will determine your horse power at a given speed. Have you ever looked at a dyno plot. Take a look the RPMS versus horsepower plot. Notice that for larger RPMS the horsepower increases until it saturates?
Well, for the Celica GT-S that did 130MPH in 5th gear at 7800RPM and only 123MPH gear at 5850RPMS in 6th gear. Well, take a dyno plot of a Celica GT-S and you will see that the HP at 7800RPM is higher than when the engine is running at 5850RPMS.
Anyway, before you start calling people stupid you should try and understand what they are talking about. Anyway, if your so smart then you'll probably be able to understand this article on HP vs. RPM:
HP vs Torque
Actually this article is better because it also explains how drag comes into it. It's also a lot less technical... However, this article shows that I was off in my previous equations (now I feel stupid, I should've paid attention in class). Anyway, read it if your interested... *edit* removed some stuff that was irrelevant.
Torque, HP, Speed
If you don't read any of the other articles read this one... It seems to be very clear.
Horsepower vs. Torque
BP5
[ 12-01-2001: Message edited by: Blue P5 ]
