fourthmeal
Banned
Am I crazy or did I just catch that you are only installing new tires on the front?!?!
New, wider, WRONG size tires, at that?
Never change the tire size unless you are doing them all (or unless the car uses staggered sizes to begin with, like a Porsche 911 for example.) Further, if you are going to go with wider tires, they need to fit properly on the wheel. The stock 18x7 wheel is not wide enough for the tire you put on. I'm surprised as hell they even did the job. Here's another part that caught me off-guard...you mention that you were looking for an All-Season replacement tire for the stock one, while keeping the summer tires on the rear...not a good idea at all.
Lastly, why did you not rotate your tires? This would allow them to all wear much more evenly, allowing you a longer run on the set, so they could be replaced as they should be...a set.
I'm really curious as to what the tire installer shop was thinking when they OK'd this.
