Simon Tibbett
- 1983 Mazda RX-7
Hello everyone.
My name is Simon and I'm new here, I figured I'd start off with a build/log thread.
The car is a 1983 Mazda RX-7. I bought it already fairly race ready so "build thread" may not mean much building other than updating/changing/updates on races.
The car was originally racing out west in Pro7 before coming to the southeast at some point. I bought it locally in June of 2012 to race with the SCCA in IT7 for now until I can't find another 12a.
I'll also post videos here: https://www.youtube.com/user/simontibb?feature=mhee
Mods:
-Header w/ full exhaust.
-Strut tower bar.
-Full roll cage.
-Tokico struts.
-Unknown springs.
-Some type of aftermarket sway bar w/adjustable end links.
-Steel braided brake lines.
-Panasport for dry/Diamond Racing wheels for wet.
-...and some other things I can't remember.
Day One:
This is the day I brought it home, it ran good, but had a stumbling issue that was known when I bought it. Previous owners cleaned the tank, new pump, you name it. Got it running better but there was still some hesitation.
Pics:
After some cleaning...I got it shined up a little better and removed the decals to make room for "my own."
After the cosmetic stuff I fixed a few small things and put a OMP blockoff plate on to pre-mix.
I decided to run an HSR event, the "Atlanta Historic Races" as a "test" to get a feel for the car. Since I don't drive it on the street it'd be my first real time behind the wheel of it. To get it ready I just did a few very minor things including new harnesses and what not.
My first session out sucked, I stuck all my Diamond Racing wheels on which I bought with fairly new Toyo unshaved tires I bought in case of rain but were in better shape than the R888s on the car, as I pulled down to grid my "crew" noticed the wheel was wobbling bad and was either loose or bent. Ended up being bent so hurried and went back to throw two Panasports on the rear.
I did get out there though with some time left. The car handled great! I was very surprised. I took it easy just getting a feel for it, biggest headache was the stumbling issue coming out of corners and sometimes on straight aways, it really limited the car. The other issue was a bad vibration above 70 or so, so I kept my speed down to around 85 tops, which sucked especially on the backstraight.
Second session went better, I went quicker and started to get more out of the car. Handling wise it felt very neutral.
Third session on Sunday was the best, because I fixed the issue. It was just the vent solenoid unplugged on the carb, plugged it in and the car ran smooth! The only downside is it "feels" slower now, not sure if it's in my head or if it really did lose some power.
In the final session I went fastest and had a blast. Car ran good, no issues engine wise.
Mods:
-Strut tower bar.
-Full roll cage.
-Tokico struts.
-Unknown springs.
Day One:
Pics:
