there is only two hoses that go to our throttle body and they are both coolant lines. If you have a vacuum leak coming from the throttle body, it is going to be from the gasket between the throttle body and the manifold. Let the car idle and spray some carb cleaner around the gasket area and see if the idle changes. Does the car idle roughly? Have a boost gauge, if so, what is your vac like? Here are some pics of the throttle body:
Throttle position sensor side, notice the two fittings where the coolant lines would go
throttle cable side
direct front shot
