princess peach
 - '92 Miata, '06 MS6
My 2 fastest laps from Nelson Ledges this past weekend: http://www.youtube.com/watch?v=3mnNwmuFa1k
#1 = 1:26.44
#2 = 1:26.66
I have to look at my video and see my times, do you have a device for that?
#1 = 1:26.44
#2 = 1:26.66
my white wheels have Yokohama Parada Spec 2 but they're pretty worn on the inside, I have no idea how they compare to yours. considering how your pads looked when you swapped them out I'm thinking you might still using the brakes too much, that's why your pressure was so high in the front (this + understeer). When I swapped my pads I was close to 40k miles and had at least 2/3 of life left on them, I don't have a turbo but you know how I drive.
Higher pressure in the rears will help you rotate but at least for me I can rotate fine with all 4 at the same pressure AND the rear sway set to soft which is pretty much your medium setting, also I gain around 4 PSI evenly after a run with the slicks but I don't know what that says about my driving. I don't think you should increase stiffness on your RSB yet, play a little with the pressure first or it might be too much and bite you in the ass. With the Yokohamas I was shooting to have 34 PSI tops all around after a run, for you I would shoot for 32 at the front and 35/36 at the rear. Next time check what the pressure is before your first run to see how much you're gaining, again I'm gaining 4 all around but I would guess you're gaining at least 6 in front
I haven't seen or heard of that unit before. Do you know anyone who is using it?
Evan, don't forget to add in the cost of a helmet with your tires.![]()
when's the best time to drop it off.
that would be a.s.a.p. so he can have his date with clarkson
I'm just busting your balls, brotha. I'll just see ya sunday. It just doesn't feel the same when I watch TopGear without my helmet. Oh how Clarkson makes me swoon...
I've actually worn the helmet on my way home from work once during rush hour traffic just to see what reactions I would get. It was pretty funny, people looked at me like WTF???????????
I tried that on Halloween last year, turns out it's illegal... still funny though
Haha...I had a feeling it was illegal, but part of it doesn't make sense...I mean you are wearing a helmet so technically you're safer in the event of an accident HAHA.
