Huber Ridge in Blendon Township. It's not far from where I was but Westerville schools and address.
Nice, I've been in that area a bit lately for a couple of customers. Benefiting from Westerville schools is a huge plus.
You should stop by and say hi
Good luck with that. He never tells me when he's in the area until after the fact. (lol2)
Coming down fro school?
I'm in Akron, right by the Rubber Bowl.
Thanks! The tires are the correct size, but either the wheels are slightly wider, or the offset is lower because the tires are rubbing at the rear. I'm going to try and push the lip in a little.
most likely offset. I had rubbing on bigger bumps with 17x8 w/ 38 offset but the 235's on the wheels were slightly larger than stock diameter (pro-kit & stock struts). Lowering springs at all or has the rear struts been changed? The MSP had a higher rear spring perch on the factory struts
