The Black Mica (16W) Thread
and i hope he understands that if you don't have a fmic with that body kit you just killed the airflow to the tmic by putting that ugly regular 6 grill on it.
To Boosted, I am a bit of an audiophile and therefore the extra weight was not an issue. Plus the speakers and amp have a quick lock system to remove all components quickly. Also after installing the new lighter body kit the car weighs less then stock even with the speakers in.
To amillie, this is a regular 6 body kit, and since the regular 6 has a shorter facade I went with a lower kit (which did look more ricer) but a less rice kit would have been shorter and would have made my car look lifted.
To bova, the only grill that would fit without showing the mounting holes since it is a standard 6 body kit was the standard 6 grill. I didn't want to do it but I had to put it on. I was afraid of the TMIC so I recorded exterior temps and driving speeds and watched my boosted air temp and intake temp. After the kit was installed the boosted air temp actually decreased by 4 degrees F and intake temp went down by 7.
id like to see a straight on shot from the front. also the back to see how the exhaust is positioned.. the look deff. doesnt sit right with me either. but then again this is the only MS6 ive seen with anything other then the HD or Autoexe lips.
Yeah I'm slammed it on BC's... Heres another pic from a mini-meet
black micaaaaaaaaaaa mmmmmmmmmmmmmmmmm
