T ta240 Sep 3, 2009 #1 Anyone know of an easy power wire to tap into under the hood that is only hot when the key is on? I need it to power some LEDs
D Dpwhitehead1 Damian Contributor : MSP 1145 Sep 3, 2009 #2 use the radio.. sooo much easier. or just use a fuse tap for the radio wire i suppose. but i run wires directly from the radio.
T ta240 Sep 4, 2009 #3 I figured I could tap into the power outlet but was hoping to avoid running a wire through to the inside
D Dpwhitehead1 Damian Contributor : MSP 1145 Sep 4, 2009 #4 well you can yeah. or you could fuse tap, like i mentioned. but running wiring into the interior is CAKE.. either way. good luck.
D Dpwhitehead1 Damian Contributor : MSP 1145 Sep 4, 2009 #6 nice! i'm thinking about doing something like that..slightly different.
T ta240 Sep 4, 2009 #7 yeah, there's probably a ton of different ways. I'm guessing some that would take more time and work would look even better but not bad for a few minutes work
D Dpwhitehead1 Damian Contributor : MSP 1145 Sep 4, 2009 #8 werd! i'm doing something slightly different than anything i've seen so far. we'll see. where'd you get your leds?
