switched power wire under hood
Anyone know of an easy power wire to tap into under the hood that is only hot when the key is on?
I need it to power some LEDs
use the radio.. sooo much easier.
or just use a fuse tap for the radio wire i suppose. but i run wires directly from the radio.
I figured I could tap into the power outlet but was hoping to avoid running a wire through to the inside
well you can yeah. or you could fuse tap, like i mentioned. but running wiring into the interior is CAKE..
either way. good luck.
got it.
yeah, there's probably a ton of different ways. I'm guessing some that would take more time and work would look even better but not bad for a few minutes work :)
werd! i'm doing something slightly different than anything i've seen so far. we'll see.
where'd you get your leds?
