Okay, getting frustrated with the string of crappy finishes in STS. The car is decently setup, but it seems I just can't get a lot of grip. I get into the corners, the front starts to understeer/push, and that's as hard as it will turn without getting out of shape. This has led to a steady stream of mid-pack STS finishes at the big events, and one 2nd place in a less-well-attended event.
I've already got Tokico's with GC coilover springs, front camber plates, rear crash bolts, Falkens (205/50-15) on stock alloys, and a stock RB rear sway bar. I've also set the car up with about 1/8" toe out up front.
I run the car pretty high, near stock ride height to accomodate northeast roads. I can lower it for AX if it would help, but haven't so far.
I've got an MP3 front bar on the way, based on the last round of sway bar articles in GRM. I'm hoping that will help.
Where would the money go next? What would I gain from the fat AWR rear bar?
Also, I'm considering wheel/tire combo upgrades. I'd like to go up to the class-limit 225 width, but there's not much available there, so it will probably be 215 width. Will I get better grip from 16's or 17's?
Any insight appreciated.
Ben
Ben
