Stock brake problem?
joelnazab
Hey how is everyone doing?... I had my front brake pads changed after about a year and a half because, I though they wore out really fast but anyways a year and a half later which is now when i brake my steering wheel starts shaking like crazy so i have to i guess change rotors and pads my thing is the front pads are more worn out then the rear pads which i have never changed sense i bought the car and that is almost 3 years ago is this normal or is my car not stopping evenly?
No, I have only changed the front rotors as well and I have had my car for 3 years also. Most of the stoping power for a car will be from the front.
ok, cool so now i need to know what type of brakes come with it i am on a low budget and will probably get some at autozone but i see there is metalic, semi metalic, and ceramic .. i want to have the same kind as stock ones also say i go with ceramic it there a special disk i need to get for it or all disk or rotors are the same?
Not sure, if you go to autozone or a local shop they should be able to tell you what is OEM. My brother does my basic maintenance for me (owns a local shop) so I don't know what we put on it, but it was under a 100 for both
