Sticky Gooy Slime Running Down Tansmission
Russm
08 MS3
Good Day
I was doing oil change 3 days ago and noticed a thin greasy/oily residue on driver side suspension A arm and top of axle dust boot, cleaned it off good and knew I was going to change tranny fluid today and check it. Today I found more of the same(some of it oily some of it more solid like grease), it is dribbling down the outside of tranny and a couple other places underneath the battery. I know the driver side MM doesn't have any gel filling,
Jason from Mazda parts Online confirmed and ask a Tech and they think it might be a hose in the PVC system cracked letting ooze out. Has anyone here experienced similar issue, and have an idea what to look for before I start taking parts out? The car is running fine, no coeds, oil is not down on dip stick.
Thank You for any thoughts!
It's a shame there are no coeds! :D On topic, I can't think of any grease-like substance that would come from the area you describe. Clutch fluid would be thinner.
Good Day
how about a tear in the inner cv boot?
I pulled everything off the top to see if something was leaking, nothing, boot is in good shape, guess I must of run over something and threw a bunch of greasy crap up the wheel well and it started to drip down. Easy fix , wiped it all down got to clean up my battery box and everything underneath and I will keep an eye on it. Thanks for the input!
