split second bug ??? WTF help !
felix1
MSP 2003.5
hello, when i try to load the supermap stock, that i dl/ here, when i open it, i only see 9 and 10 !! what ever the map i am loading like i tried many other, and there is only always 9 and 10 !!! now my car cant even go in boost it just buck and lean the **** to hell, any idea of what is going on ?
help ? is there any procedure to do WDF, even without the AFC the car run better and yesterday it was working ? duh
ok, after some test now i know the problem is the afc itself, when i unplug the vacuum hose, the car stop having hudge hesitation but still running too lean at 14-15 on boost, whats up with my afc dam it !
all i did was to try to upload the supermapstock again to the afc, and now idk what is going on, i tried to disconnect the battery but didnt change something, i have no check engine, and the only thing i did was to unscrew 4 bolt and remove the cover of the AFC ? 0-o
what is the overpressure set at under options? At what psi does the 10 change to 9? A value of 10 has no change to the fuel map. Anything under 10 takes away fuel and above 10 adds fuel.
Well the value are the same as the supermap stock u can find in the thread of map in the forum here, i didnt touch anything else beside loading the supermap back, like i said my car was running fine yesterday!! Near perfect at 12:1 with 8 psi.. They start to change at 6 psi i think! But i have the feeling the the cr is staying in open loop, its wierd , when i unplug the vacuum hose on the afc the car will run like a normal msp with some hesitation at 3000 rpm, but with the afc plugued, my wide band go top lean ( aem uego ) normally without afc it goes top rich its just wierd,
how come when i try to load any map, there is no number after the .
all i see with the supermap is only 9 and 10 nothing else !!! this is not normal ...
Have you tried loading the R4 software on another computer? Maybe it's just a display issue where the columns aren't wide enough on your pc or the font is too large?
