Spark Plug Torque Settings
Camshaft
2011 Mazda2
I'm looking to change out my spark plugs this weekend or next and I need to know what torque settings the factory calls for. Looks like NGK BKR5EIX-11s are the plug everyone recommends, but I couldn't find torque settings listed.
torquing spark plugs is not like torquing a regular bolt. USUALLY, it finger tight + 1/8 to a 1/4 turn, depending if there is a sealing washer used or a taper seat. i believe the Mazda2 head uses a taper seat for the plugs, so it would be finger tight + 1/8 turn. check with the plug manufacturer for specifics. (should be printed on the box)
