Quick Question, How in hell do you remeve the Radio Center console ?? I tried to many time but no luck, the damn Wires that are attach to the AC controls dont give me enought room to do s*** --- any tips....... Thanks.
1. Detach the climate control cables from their posts on the white plastic wheels. There is one on each side under the dash. To get to the one on the passenger side first remove the glove box (squeeze on one side and it will drop down).
2. About 6" back from the end there is a black plastic clamp holding those cables, pull them out of the clamp. (Carefully, that sucker has some very sharp edges.)
3. Tie a string to the end of each climate control cable so that you can be sure to route it back the way it was originally.
4. Aim the vents up.
5. Stick your hands in the vents and pull down and away from the console.
6. Detach the emergency flasher cable.
7. Pull the console out a little farther and detach the climate control wires.
8. Pull the console with the climate control unit out the rest of the way.
9. Detach the strings and tie them off somewhere, so that the path they mark is maintained.
On an automatic if the shifter is in park it will get in the way. Chock the wheels, put on the parking brake, and move it as far away
from the console as it will go.
Reassembly is the reverse, and you can use the strings you left in to help pull the cables through. Without the strings you will probably have to stick your hand into some tight places where there are lots of sharp metal edges.
