Off Topic: So slow I'm ashamed...
The rear should be exhausting though...you want that heat exiting. This should not make things dusty.
If I had a traditional air cooler, then yes, rear would be the exhaust. But because I'm water cooled, you want that fan blowing in (according to everything I've read).
Besides, because of the case design, there's plenty of extra exhaust from all of the vents above the card slots.
You're working against the intake of the front that way, but you are probably getting slightly cooler air to the radiator, but not sure it's much. Personally I'd flip it, but that's just me.
You OK, bro? Where you been? LOL I was waiting for you to reply because...
I knew you'd agree with me.
It'll be fine, it certainly doesn't hurt anything. My thinking here is even if exhausting the back somehow does get MORE dust inside your case.... people like us occasionally check our cases to make sure they don't need a quick cleaning.
:D #Geek
:D #Geek
I'm good, just not been good at keeping up with most of my forums lately. :ROFLMAO:
Bought a $20 HD 6850 for the Cheapaz Chips competition on HWBot. Now looking to pick up some stuff for voltage modding from Elmor Labs for it.
As for gaming, I finally tried Cyberpunk. Looks good, but crashed a lot for some reason. Replaying Subnautica.
Well been wanting to start building an open air test/OC bench. To that end, I scored a killer deal on a used EVGA Z790 Kingpin board to be the foundation. I think might hold out till 14th gen comes out to get a CPU though as its a Raptor Lake refresh so should be on same socket and chipset.
Will take me a while to get all the parts for this, but looking forward to it.
Well, my 1080TI I think was dying. I got this screen a few times...
Ss reluctantly, I replaced it with a 4060Ti. It uses a TON less power, and benchmarks out a hair better. Here is my original system benchmark as set up in 2017, then with my 1080Ti in 2019, and today, my 4060Ti.
2017
2019
2023
I purchased the 4060Ti in hopes of maybe a small performance bump, but mainly because it was $400 and would run MUCH cooler and on less power than my failing 1080Ti. What impresses me most is that the 4060Ti is a VERY new card, and NVIDIA is treating it as mid-tier, and the 1080Ti still hangs right there with it pretty much, even though it's half a decade older.
Before I pulled the 1080Ti, I ran the benchmark on Ghost Recon: Breakpoint with it. Everything maxxed out at 1440p:
Then I ran the 4060Ti, same:
You can be impressed by 2018 technology holding up super well to 2023 technology, or you can be impressed that after half a decade of COVID inflation, you can get about the same performance for 1/3 the price burning 1/2-2/3 the electricity.
PS: The 1080Ti is up for sale, with the full disclosure that I DO NOT GUARANTEE IT TO WORK. I DID provide the above benchmark minutes before it was pulled, though. I have been told that if you add thermal paste/replace it, it could fix this. It provides the messed up frozen screen/system initially pictured after gaming for a while and tabbing in/out of game. Price is obviously negotiable and I am open to offers. Again, this card is guaranteed to HAVE A PROBLEM. The severity of which, I am ignorant of and just detailed above. If you take a brick out of the bag, that's on you, but I've been transparent about it and no takesie backsies.
2017
2019
2023
What your screen is doing right now is called artifacting. The only way a repaste/repad is going to maybe fix that is if the source of the problem is overheating. But if the source of the problem is overheating, then that damage could be cumulative over time. I don't suppose you ever tried any utilities like MSI Afterburner to see what your temps were under full gaming load? If it's not an overheating problem then the GPU is 100% dying. As long as you are selling that as a dying card or for parts only (and price reflects that), then that shouldn't be a problem. I wouldn't try to sell that for whatever working used 1080 Ti's are going for.
As for your points on the 4060 Ti, the 1080 Ti absolutely hang up there with modern stuff for sure. The newest generations of cards have raised the prices so much beyond what is reasonable to expect for mere inflation that the needle for generational performance gain for same money just isn't there. For whatever you spent on the 1080 Ti, the needle just hasn't really moved much for upgrading performance significantly for the same money. That's largely due to Nvidia raising prices to reflect pandemic level margins with regards to the 40-series.
For the 40-series, most of the stack of cards are way screwed up on pricing and have also been completely misbranded for what they are in the stack. The 4080 uses a 379mm2 die which in any other generation would be considered solidly mid-range, and yet they are trying to sell it for 4080 Ti prices. The 4070 Ti has the performance characteristics of what were just base "70-class" non-Ti cards of the past (matching the previous gen's flagship). Yet they branded it a Ti and raised the price. The 4070 has a similar story as it's performance characteristics and cut down die used should have made it the 4060 Ti. And then there's the 4060 Ti. It uses the die that would typically be used for 60 or even a 50 Ti card, its performance characteristics are more of that of a typical "60-class" card. There is also the point many have made about 8GB cards being sold in 2023 for $400+ being absurd, but the point could also be made that it might not even matter depending on your use case and what you are playing.
All this to say, yeah on one hand I am impressed about the power you can get in much more efficient cards. The 3090 Ti was a 450W card (stock) and the 4070 Ti matches it at 285W (stock). On the other hand, the pricing is absolutely insane for what the cards actually are.
I did a small refresh on my PC last week. I upgraded my Ryzen 3600 to a 5700, and I bumped my RAM from 32 GB to 64 GB with matching model numbers. 3 years old and still running strong.
Most annoying thing was my DisplayPort cable magically failed during the install. I plugged everything in and the computer wouldn’t post. VGA error. I was like you’ve got to be kidding me. I updated the BIOS and everything, what the hell could be wrong? Pulled the cable after reseating the GPU and passed post. Still couldn’t get a picture after several reboots and trying HDMI, and by some magic it finally providing video via HdMI.
I must be doing something wrong with the PBO and curve optimizer though. I tried multiple settings to overclock and I was actually getting worse Cinebench scores. After a few hours I gave up and reverted settings back to default in BIOS. Just running with that instead, no big deal.
PBO might give you better single core scores due to higher single core boosts, but the best scores for CB R23 multi-core will come from just doing the highest all-core OC you can get (limit being your cooling). That's how I got 24k on my 5900X while PBO+CO was at best giving me 22-23k.
That said, I wouldn't leave it on an all core OC for daily driving if you do things like game because then you are sacrificing the single core boosts from PBO+CO.
At least that has been my experience with the 5900X. You'll probably have an easier time than me with the 5700 due to the single CCD design. The 5900X is functionally two 5600X's on the same package (dual CCD design), and the first CCD is much better binned than the second CCD on mine.
Ultimately I gave up trying to manually do anything with Curve Optimizer and getting stable 24/7 results with it. Something always ended up exposing instability with my negative voltage offsets I set manually even after painstaking stability testing. At this point I put that back to Auto with PBO just set to be auto with +200 MHz offset, which should help your single core boosting.
Going forward, I plan to stick with Intel for the machines I want to OC with, and AMD X3D maybe for daily drivers I want to just set and forget. My test bench for instance now has a 13900KS on it. I would never run that power hog on a daily driver, but its much more interesting for tinkering.
I bought my PC back in 2017. Since then, I upgraded the PSU, and graphics card, and added another 32gb of ram.
It began:
i7-7700k
1080gtx--->1080ti--->4060ti
32gb 2133ms----64gb
500w PSU--->850 gold+ PSU
Anyway, it's no longer pulling the performance I want, so...
i9-14900kf
Gtx 4080 Super
32gb 5600ms
Im proud to have gotten 7 years of use out of it with minor plug and play upgrades. How long do you all usually get from a PC?
i9-14900kf
Gtx 4080 Super
32gb 5600ms
BEAST. For real.
I can generally get about 7-10 years out of a build anymore. I went from a 4790 to a 12700K. That's 8 generations! And I still have the 4790 upstairs, it's my bedroom computer now.
The question I want to know is, why do I have 10 PC's and 5 laptops? I really need to thin the herd. I'm going to put a bunch of them for sale when back-to-school starts and people are looking for something cheap but functional.
My rig: i7-12700K with RTX4070Ti
Wife's rig: Ryzen9 5900X with RTX3060Ti
Older son's rig: Ryzen5 5500 with GTX1080Ti
Younger son: i7-14700K with RTX4070Ti
Bedroom: i7-4790K with GTX1660Ti
Backup to that one: i7-4790 with GTX1050
Backup to that one: i3-4160 with GTX1660Ti
Backup to that one: i5-3550 with GT1030
XP gaming rig: Athlon64 X2 7750BE with some random video card I can't remember
Finally a Core2Quad (I think, I can't remember, because it just works and I don't mess with it. I just turn it on and it works flawlessly) running my MAME cabinet.
This is the wife's rig. And yes, that's Strawberry Shortcake and Holly Hobbie in there! She loved those characters when she was a little girl.
I bought the PC that I'm currently using back when I retired in 2014 and its still working just fine for what I use it for. No gaming on the PC, that's what the PS is for.
Although I did have to have the motherboard replaced under warranty way back when.
I used to be into building my own, in fact that was part of my job. I tired of it and a PC off the shelf did what I needed, so...
It began:
i7-7700k
32gb 2133ms----64gb
i9-14900kf
Gtx 4080 Super
32gb 5600ms
Depends. I ran my last PC on the daily from 2015 through 2022. It was a 4790k / GTX 980 and was still perfectly fine at 1080p. It's when I started upgrading displays and especially resolution that it became woefully inadequate.
My daily rig right now is still on the 5900X and 3080 Ti. I've found the 12GB on the 3080 Ti inadequate for a couple games now on my 4k OLED display, so will probably upgrade again sometime next year when the new stuff is out.
I have a 13900KS on the test bench, and let me tell you it needs a hell of a lot of cooling and tweaking to keep from thermal throttling. I'll be excited to see what the next gen Zen 5 X3D and Arrow Lake releases bring. Supposedly some big architectural changes for both camps.
As for graphics, I would shoot for a 5090, but I have a feeling they are going to be priced even stoopider, so will see how the 5080 looks.
My most recent upgrade was moving the 48" C1 OLED to the living room and grabbing a gentle used but way discounted from new, 42" LG C4 for the daily rig. I'm finding the 42" size much better for my desk than the 48". I wouldn't want to go smaller though.
I went over 20 years without building a PC. It was so long, up until last year, the last computer I built myself had a GeForce3 Ti200 in it! That was what? 2001? Off-lease Prebuilts are just so damned cheap. I had a lot of catching up to do. Everything, and I mean *everything* changed. Optical drives aren't even a thing anymore. This SUPER weirded me out.
It began:
i7-7700k
32gb 2133ms----64gb
i9-14900kf
Gtx 4080 Super
32gb 5600ms
Nice to see you posting here again! What is the current drive your have?
New Threads
