so check out what little surprise I had for me today....
fishdonotbounce
Registered Zombie
08.5 CWP Speed3
so i installed a bomz intake about 6 months ago or so and what i didnt realize was that the fitment wasnt as good as i thought it would be.
Well after 6 months of the engine moving slightly back when i shift into drive, a hole developed from it hitting one of the stationary objects in the engine (i have no idea what the part is. My uncle and i spent 4 hours patching the hole up with this stuff i now call miracle tape, and a piece of plumbing rubber that is strapped there to cushion any further contact.
In all, we had to cut the pipe about a quarter of an inch and had to do some pulling and tugging to get everything to fit on top of doing a bunch of other s***. Now, I am stuck with a patched up pipe. Here are the pictures so you can see for yourself. Sorry the second pic is blurry i was riding in a car to Lowe's.
Shot at 2007-08-07
Shot at 2007-08-07
That mystery rubbing part is probably called the brake master cylinder if your talking about the bend nearest the throttle body. Pics are a no show.
Yup, that's where they all hit the brake master cylinder.
Our engines move so much, it's difficult to tell while installing, how much clearance you'll need.
Yeah I see them, bummer bro just installed mine today to.. hopefully that doesnt happen soon
If you cut a 1/2 an inch of the pipe where it goes into the intake it will clear the brake master cylinder no problem
you're hitting the master cylinder. generally, cutting a piece off of the piece that goes to the throttle body, or just plain tweaking the fitment, will fix that
