Smart Brake Error Messages
Hello,
Once in a while my 2018 cx5 touring showing "smart brake system malfunction" and "forward smart city brake support malfunction" error messages.
So I went to AutoZone and done the scan.
Code c0023-62 (Stop Lamp Control-Signal compare failure) came up.
Sounds like my car needs a new brake light switch
My question is:
After replacing the switch,, Do I need to reprogram my car's computer?
Thanks!
Update:
It's been a week since I replaced the brake light switch. Error codes are gone. Problem solved!
Upvote 0
Solution
I've been seeing random smart brake on the dash. Mostly during cold weather. Was it the "brake light switch" at the pedal? I have 2017 so its as different p/n of BN7N-66-490 ... aka Stop lamp switch.
N7Turbo's comment is also thoughtful as it could have been dirt/ice, other, on the windshield where the camera is for the SmartBrake system. Keep those windscreens clean! :)
Upvote 0
The error trips for a variety of reasons. Usually full
obdii scan will show more info and often times show other modules with errors which may give clue.
Its a mazda fail safe logic to disable SBS,MRCC, etc for certain conditions and it shows on the screen.
I had same error once or twice and it was the front camera which got blinded.
Upvote 0
