Running lights won't turn off and TCS won't turn on (2007 CX-9 GT)
So my sun roof drain was clogged and leaked water behind the driver side dash. Now my running lights won't turn off and my tcs wont turn on. Any ideas on a fix?
Do you mean 2017? You might have to disconnect the neg terminal on battery to keep from running down your battery until you can get it fixed.
water going in ECU and stuff is pretty bad, you know the problem, now you need to take it apart and what the water did as far as damage.
2007 I figure your right Puma. I will pull the BCM tonight and try to dry it out better. Hopefully I wont have to get a new one. I will take other suggestions though. Wlong it is a 2007
