The stock amp is not being utilized to it's full potential using the stock sub because it is only 8 ohms. You will double it's output by connecting the 8w3. Then it will be fine. I would buy and install the 8w3 first. Then decide from there what else you want to do.sr240z said:So The Stock Amp Is Fine Or Is It Not Utilizing The Sub To Its Fullest Potential?
sr240z said:Sweet.... So For That Amp I Would Have To Run 8awg Wiring Or 4awg?
Also I Would Like To Keep The Amp Close To The Sub So Could I Run That Amp In The Stock Location Or Would It Need More Ventilation?
