Red-stripe In-Dash GPS Installed!
Did the unit come with any specification on it? If it did can someone post a pic or scan of them?
Can any one post pics of the gray one installed?
How many rca outputs?
How many video outputs?
THD of outputs?
Signal to noise ratio of the outputs?
County of manufacture?
Manufactures name?
How many volts are the RCA outputs?
How is the video quality?
Is there a power antenna/remote wire?
Thanks in advance to anyone who can provide any of these answers. BTW they look great, I just want to know that the internals are worth $810....
This thread is for the redstripe unit, you might have better luck starting a new thread for the unit you are talking about as they are vastly different.
Ok after a long weekend of reading and downloading I finally got a version of iGo8 working on this thing. I could never get tomtom to work, Im on a mac and couldn't run those cmd files and keygens. Tried TT on my buddies PC but we still had no luck. So I went the iGo8 route and after a few tries and a bunch of different downloads/ sys file hacking it works pretty good. It did crash once, but i was trying all the menu items real quick trying to get it to crash.
I will get some pics up tomorrow.
I'm trying IGo as well, but I have some problems with the screen resolution, could you post your system.ini file so I can take a look at your rawdisplay settings! Thanks
-Zips
Here is my sys.txt
You should be able to copy and paste it.
[interface]
skin="ui_igo8"
resolution_dir="480_234"
vga=0
show_zoombar=1
maxzoom2d=6000000
minzoom2d=40
show_exit=1
defaulttilt3d=7600
[rawdisplay]
class="landscape"
highres=0
screen_x=480
screen_y=234
[debug]
skip_eula=1
slowsim=0
enable_roadshadow=1
sound_q_length=250
show_device_type=0
show_rawdisplay_info=0
enable_3D_buildings=1
enable_roadsign=1
enable_landmark_occlusion=1
show_oneway_3d=1
show_gps_pos=1
showcenter=1
show_speed_limit=1
show_icons=1
show_arrows_on_route=1
follow_gps=1
earth=1
autosave=1
tts_min_ready_wav=1
tts_getaway_time=200
tts_expected_engine_delay=1400
reserve_memory=2097152
[msnd]
msnd.start=0
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
always_say_road_names=1
announce_street_name=1
announce_exit_directions=1
skip_exit_numbers=0
[sound]
queue_length=200
;ding=0
[poi]
poi_show_all_btn=1
poi_labels=1
show_poi_boundingrects=1
show_poi_areas=1
[map]
auto_nightmode=0
popup_info=1
shields=1
textured_poly=1
3d_max_tiltlevel=9000
3d_max_zoomlevel=3000
3d_min-zoomlevel=40
3d_max_zfar=2000
3d_landmarks=1
3d_buildings=1
3d_buildings_distance=1
3d_dem=1
3d_roads=1
3d_tunnels=1
3d_scale_carmodel=1
[smartzoom]
minangle=0
maxangle=80
[warning]
speedwarn_alt_builtup_based=1
speedcam_warning=1
speedlimit_warning_visual=1
[gps]
port=6
baud=4800
protocol="nmea"
One thing is you have to make sure you are using the correct maps for the correct version...8.0 maps for the 8.0 version and so on.
Working on getting the folder zipped.
Here is my sys.txt
[interface]
skin="ui_igo8"
vga=0
show_zoombar=1
maxzoom2d=6000000
minzoom2d=40
show_exit=1
defaulttilt3d=7600
[rawdisplay]
class="landscape"
highres=0
screen_x=480
screen_y=234
[debug]
skip_eula=1
slowsim=0
enable_roadshadow=1
sound_q_length=250
show_device_type=0
enable_roadsign=1
show_oneway_3d=1
show_gps_pos=1
showcenter=1
show_speed_limit=1
show_icons=1
follow_gps=1
earth=1
autosave=1
tts_min_ready_wav=1
[msnd]
msnd.start=0
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=0
[sound]
queue_length=200
;ding=0
[poi]
poi_show_all_btn=1
poi_labels=1
show_poi_areas=1
[map]
auto_nightmode=0
popup_info=1
shields=1
textured_poly=1
3d_min-zoomlevel=40
3d_max_zfar=2000
3d_landmarks=1
3d_buildings=1
3d_dem=1
3d_roads=1
3d_tunnels=1
3d_scale_carmodel=1
[smartzoom]
minangle=0
maxangle=80
[warning]
speedcam_warning=1
[gps]
port=6
baud=4800
protocol="nmea"
Thanks Keith !!
-Zips
Hey guys, so I got the same unit and installed it this weekend. (I have a 2007 speed3) the questions I have.are: Has anyone been able to get the AM radio to work? On my unit it gets no AM receptionand the tuner skips every 9 channelsnot sure what thats all about??(shrug) Also the Bluetooth is workingand the LCD is showing the clock and temp.but there is no display for the mode its in (ieDVD.CD.Radio) its just blank in the middle. Also when I go to the option to set the Clock it dose nothing.hit setor the down arrow and nothing happens. Is that supposed to bring you to a new screen? Could this be the CAN+ CAN- issue? Or do you think this has something to do with me having a 2007?
Thanks so much for any help!!
Sounds like the CAN+/- issue as far as the bluetooth and display. Not sure about the AM stations. Who listens to AM anyway? :P
I do. I wanna know what the traffic is like and they do it every ten minutes. Can others confirm AM works?
Here is my sys.txt
[interface]
skin="ui_igo8"
vga=0
show_zoombar=1
maxzoom2d=6000000
minzoom2d=40
show_exit=1
defaulttilt3d=7600
[rawdisplay]
class="landscape"
highres=0
screen_x=480
screen_y=234
[debug]
skip_eula=1
slowsim=0
enable_roadshadow=1
sound_q_length=250
show_device_type=0
enable_roadsign=1
show_oneway_3d=1
show_gps_pos=1
showcenter=1
show_speed_limit=1
show_icons=1
follow_gps=1
earth=1
autosave=1
tts_min_ready_wav=1
[msnd]
msnd.start=0
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=0
[sound]
queue_length=200
;ding=0
[poi]
poi_show_all_btn=1
poi_labels=1
show_poi_areas=1
[map]
auto_nightmode=0
popup_info=1
shields=1
textured_poly=1
3d_min-zoomlevel=40
3d_max_zfar=2000
3d_landmarks=1
3d_buildings=1
3d_dem=1
3d_roads=1
3d_tunnels=1
3d_scale_carmodel=1
[smartzoom]
minangle=0
maxangle=80
[warning]
speedcam_warning=1
[gps]
port=6
baud=4800
protocol="nmea"
awesome, can't wait for the pictures. I heard this is the nicest looking/best working GPS, how do you like it thus far?
Well I found a supposed full version of Igo8. It seemed the folder has all the proper files, but when I put the card in the unit, browse for the igo.exe select it and it acts like its going to run, but then pops up an error screen that says it can't find data base?
What version of tomtom should I be looking for?
I got the same error, what was your remedy?
for anyone running amps with this unit, what wire did you use for the turn on wire? Im not haveing any luck with the one im useing. getting a very bad pop on turn on and I dont have cheap amps. soft turn is working but the unit has to boot up so the soft turn-on on the amps is to fast.
wow...it look really good...wish my MS3 would of at least come with a option Nav system. can i do this or even the top mount Nav on my 09 MS3? i would love to have this. if some can please fill me in on this. thanks. looks good.
I have an '09 and this unit works great (even w/Bose system). You could also do the top mount, but if it is touch screen you have a long reach to use it.
Sweet....im gonna save up for this...yea i like the top mount but i love the indash one better. thanks for the info.
(p5black)
So you loose the trip computer? I didn't realize that it is a part of the head unit.
Same question. What are ppl using for the turn on ( remote) wire?
So I messed up in the settings trying to get the GPS to work. Now whenever I put the unit into NAV mode, it takes me straight into this white screen touch calibration mode. The screen is unresponsive on this screen, but works normaly in other modes. I can't seem to back out of it. Is there a way to boot into windows CE? Is there a way to force a factory reset mode? Frustrating...
